Hello, I’m working on a script and I need help. I want to be able to create intersection points on curves that are not flat, in this case at different heights.
def project_lines_to_objects():
objects = rs.GetObjects("Curve", rs.filter.curve)
if not objects:
return
while True:
curva_desenhada = rs.GetLine()
if not curva_desenhada:
break
rs.EnableRedraw(False)
p1, p2 = curva_desenhada
linha_desenhada = rs.AddLine(p1, p2)
if not linha_desenhada:
continue
for obj in objects:
projected_points = []
if rs.IsCurve(obj):
intersections = rs.CurveCurveIntersection(linha_desenhada, obj)
if intersections:
for intersection in intersections:
if intersection[0] == 1:
pt = intersection[1]
projected_points.append(rs.AddPoint(pt))
rs.DeleteObject(linha_desenhada)
rs.EnableRedraw(True)
