Curve and Surface same direction offset
Hello everyone,
Im driving myself mad with this script.
I need to offset curves and surfaces in the same direction but the more I try the more it gets messy. I will appreciate any help. I have attached the script with internalized data.
Thanks in advance!!
UNFOLD-LAYOUT-DIM 011 - WEST - Copy.gh (297.4 KB)
internalize the files
they are internalized
the code has 32 toggle functions
its driving crazy to on / off them
well what is your question here off the curve or surface
is it in the model or after unrolling
what you r planning to make the out come
regards
rajeev
Hello @Rajeev2 I have attached a snip of the issue. I need to offset multiples curves inside, create a few surfaces from them and extrude them. The issue is that some curves will offset outwards rather than inwards and when extruding them or offset srf, some of them will do it in the opposite way. I have nearly 400 triangles and dont want to pick them manually and flip them (I also tried that, but fail in the process).
I also attached the final outcome.
i have tried something u can check out the rest
UNFOLD-LAYOUT-DIM 011 - WEST - Copy _edited_r00.gh (306.8 KB)
