The picture below contains some question.
Thanks in advance for everybody, who can help.
tibor
ps: and if You see the “V” parameters, one is Periodic degree, the other is Closed degree…what is the different and how can I convert one of them into the other? …thanks
Hi rajznyolc -
If you make a closed curve using the Curve command with Sharp=Yes and Sharp=No you can see the difference between non-periodic and periodic - basically, periodic curves and surfaces have seams which cannot develop a kink - they are always smooth across the seam. Use MakePeriodic/MakeNonPeriodic to convert between the two. Periodic curves have ‘extra’ control points that wrap around the curve at the ends - the curve or surface overlaps itself in both directions- you don’t get to see these though - you only see and interact with the parts ending at the seam location.
Rational curves and surfaces have point weights that vary - use the Weight command to see and edit point weights on a circle (rational) and a curve from the curve command, (or a Circle modified using Rebuild).
The curvature of the Rhino surface appears to be continuous to me - it does drop to zero at the seam, but as far as I can see it remains continuous- that is, the outer graph line is not broken.
Dear Pascal,
thank You very much…I understood everything and solved the problem.
(T-Spline created a non-periodic surface and played a trick on me…I created (the darker blue part) manually a (rebuilded) surface, which was periodic.)
Thank You again, You helped me a lot.
Regards,
tibor
Date: Wed, 19 Nov 2014 15:59:04 +0000
Subject: [McNeel Forum] [Rhino for Windows] Curvature Graph?
November 19
Hi rajznyolc -
If you make a closed curve using the Curve command with Sharp=Yes and Sharp=No you can see the difference between non-periodic and periodic - basically, periodic curves and surfaces have seams which cannot develop a kink - they are always smooth across the seam. Use MakePeriodic/MakeNonPeriodic to convert between the two. Periodic curves have 'extra' control points that wrap around the curve at the ends - the curve or surface overlaps itself in both directions- you don't get to see these though - you only see and interact with the parts ending at the seam location.
The curvature of the Rhino surface appears to be continuous to me - it does drop to zero at the seam, but as far as I can see it remains continuous- that is the outer graph line is not broken.
To respond, reply to this email or visit <a href="http://discourse.mcneel.com/t/curvature-graph/14067/2" style="text-decoration:none;font-weight:bold;color:#006699;color:#666;" target="_blank">http://discourse.mcneel.com/t/curvature-graph/14067/2</a> in your browser.
Previous Replies
November 19
tibor
To respond, reply to this email or visit http://discourse.mcneel.com/t/curvature-graph/14067/2 in your browser.
To unsubscribe from these emails, visit your user preferences.
