Instead it pastes some random text from the clipboard. Most of the time it’s the code line from the script under Ctrl+Shift+C. Just tested Ctrl+Shift+D = works as intended.
Option Explicit
Public BPObjects, BPBasePoint
Call BasePointCopier()
Sub BasePointCopier()
BPObjects = Rhino.GetObjects("Pick objects to Copy",, True, True)
If Not IsArray(BPObjects) Then Rhino.Print "Copy cancelled":Exit Sub
BPBasePoint = Rhino.GetPoint("Pick a base point")
If Not IsArray(BPBasePoint) Then BPObjects = Null:Rhino.Print "Copy cancelled":Exit Sub
Rhino.Print "Object(s) copied"
End Sub
Option Explicit
Call BasePointPaster()
Sub BasePointPaster()
Dim TargetPoint
If IsNull(BPObjects) Or IsEmpty(BPObjects) Then Rhino.Print"Nothing to Paste":Exit Sub
If IsArray(BPObjects) And IsArray(BPBasePoint) Then
TargetPoint = Rhino.GetPoint("Pick a target point")
If Not IsArray(TargetPoint) Then Rhino.Print "Paste cancelled":Exit Sub
Rhino.CopyObjects BPObjects, BPBasePoint, TargetPoint
End If
End Sub
