Creating Wall from polyline
Hi everyone,
I feel bad for asking that but there is a way of creating closed wall in revit through RiR? @Japhy
This is the result I want to get:
Revit says I can only use lines, arcs or ellipses… but using lines you get 4 different walls without welded edges. In fact, if you draw a wall in revit you can create it by using a closed polyline
Thanks in advance!
You’ll want to toggle Allow Joins when placing
