Hi guys. I have a simple python script that creates a few layers with different colors which I think I based on a script I found from Helvetosaur here on the forum (I think). Now I’m wondering how I can create one Main layer and have the 3 layers be created as a sublayer. I’ve been trying this trick with Mainlayer::Sublayer but somehow I couldn’t get it to work. Anybody that could help me out here?
import scriptcontext as sc
import Rhino
layer = Rhino.DocObjects.Layer()
def AddLayers():
layernames = ["Layer1", "Layer2", "Layer3"]
Colors = [(255,0,0), (0,255,0), (0,255,255)]
Count = 0
for x in layernames:
layer.Name = x
sc.doc.Layers.Add(layer)
rs.LayerColor(x, Colors[Count])
Count += 1
AddLayers()
AddLayer() has some optional arguments including ‘parent’ - which you can use to specify a parent layer if you want a layer to be its sublayer. The parent layer has to exist first.
Thus, create your parent later and then add your sublayers:
def TestAddSubLayers():
parent_layer="MainLayer"
if not rs.IsLayer(parent_layer): rs.AddLayer(parent_layer)
sublayernames = ["Layer1", "Layer2", "Layer3"]
for i in range(len(sublayernames)):
# Color is also directly specifiable
rs.AddLayer(sublayernames[i],color=Colors[i],parent=parent_layer)
TestAddSubLayers()
Just out of curiosity: On that for loop, why do you both use something like “range(len(names))” instead of just “names”? I would think the way I did it is faster (as in, less typing) so I assume there’s a reason why you’re doing it like that?
Hi ,
I just tested your sub layer script and Layer1,2 and 3 are created as layers.
It correctly created MainLayer and then created the others as new layers not sub layers. This is on ver 7 on mac…is this still a problem ?
Giusseppe
the parent option stopped working a long time ago, i remember to report it but it never got fixed. The workaround is to give rs.AddLayer the fullpath instead eg:
