I am trying to have within the “ChangeLayer” command and in the option to create New Layer… a Sublayer.
I do not know what to write so it can direct my objects into a sublayer. Is it possible at this moment?
For example, I wish to move some texts to the sublayer TEXT. This sublayer, is under a “Master” layer.
Within the command I want to create the new Master layer and also the sublayer TEXT.
Master
-TEXT
The idea is that I wish to create a macro button. I will select the texts that I have in the model space, and with this group of commands, the texts will move into the new sublayer TEXT.
Hope it is understandable…
Thank you,
So, if i understand correctly, you want to create a new (empty) master layer with some name, and then a sublayer of that new layer with the name Text - then throw all your selected text objects into that sublayer - is that right?
I think that’s only possible with a script currently…
Something like this:
def ChangeTextToNewSublayer():
objs=rs.GetObjects("Select annotations to change layer",512,preselect=True)
if not objs: return
while True:
newName=rs.GetString("New parent layer name?")
if not newName: return
if rs.IsLayer(newName) and rs.ParentLayer(newName)==None:
resp=rs.MessageBox("Parent layer name already used!",49)
if resp != 1: break
else:
p_layer=rs.AddLayer(newName)
t_layer=rs.AddLayer("Text",parent=p_layer)
rs.ObjectLayer(objs,t_layer)
break
–Mitch
Thank you! We will try this
