Hi, I’m trying to create the shape as shown in the canvas using the list of vectors I have. I’m looking at using loop. Any Idea? Thanks vectors.gh (9.2 KB)
No need to use insert item
There is if you don’t set PLine ‘C’ (Closed) input to true (Invert). That part is unnecessary(?) and probably wrong?
Disable ‘Invert’ on the PLine ‘C’ (Closed) input to see what I mean. Seems more correct to me than assuming the list of vectors is a closed loop?
Whether closed polyline enabled or disabled, the the point with coordinates (0,0,0) is unnecessary
Thank you Guys for your all your replies. I believe it’s kinda tricky but I’m seeing potential solution…
Pls note that the first line should start from the origin.
Hey,
On Seghier’one, I think it was starting from origin.
Anyway here how I’do it, with few more option that I find useful.
cheers,
MaVector.gh (8.5 KB)
