I am trying to create a sort of a knot and have a hole go through. I managed to create the geometry using pipe, but since I want this “fat” node, it creates a closed polysurface with intersecting surfaces which does not let me do any operations. I have tried to shrinkwrap it but also with the mesh it doesn’t seem to work. I have also created a NURB from the mesh but to no avail. Neither with Makehole nor with intersection nor with slice it works.
First, turn on history. I’ve right-clicked and checked “always record history”. It doesn’t seem to be obeying not for me at least… but anyways, click this button each step (don’t worry it’s only a few):
Now this part might suck, but it involves manual point editing. You can select the curve, use “PointsOn”, then set your selection filter to Control Points only, and manipulate the curve:
If you sweep with multiple shapes you could also use OrientOnCurve and place circles within the knot… then tighten those up to squish the string section within the actual knot to make it “tighter”.
This was a simpliefied example for a similar problem.
You might have to duplicate the object and use surface trimming to split the knot into separate pieces. Cap these and union the first with the second and so on. If you’re still having problems, please post your Rhino file.
