I am very new to Rhino so kindly accept my apology in advance if I am being very naive in the following.
I need to construct a hemisphere (as shown in the attached image) for my assignment work. WIth the default/standard features in rhino, I could construct only the full sphere which intrinsically comes with the two extraordinary points (at the top and bottom). But, such points in the sphere mesh are not desirable in my case.
Therefore, I was hoping for some help from you guys in constructing something similar to one shown in the attached image. Thank you so much.
That post includes the construction of a full sphere using six patches. With that approach, I agree that a sphere can be created without having any extraordinary points.
But, here, I am looking for the creation procedure of a hemisphere. I am not sure if I can construct the hemisphere using the similar six patch approach.
Generating the mesh in the bulk is not a focus here. Just the hemisphere (even the hollow one) would be fine as long as it doesn’t have any extraordinary point at the bottom while using more elements at the surface (as shown in the attached image of my first post).
I will be happy if you could describe the construction procedure.
But, even with this way, I get an extraordinary point at the bottom of the hemisphere (a common junction points for the mesh wires used to construct the sphere). This one will end something like this (see attached image), which is not desirable.
Yes, now it looks very close to what I am looking for.
Although @jeremy5 has explained me the starting the point and other important things. But, your final geometry is looks more sophisticated. So could you please explain the construction procedure for the setup.
In the WIP , I made 2 quadspheres in SubD.scaled 1 smaller made an intersecting plane . Split both spheres by the plane. Split the plane joined up . Then converted to nurbs. Hope it helps. —-Mark
