Hello everyone! Can one create a custom sort for curves?
Example code:
x.Sort(new CustomCompare());
class CustomCompare : IComparer
public int CompareRegionRelashionship(Curve x, Curve y)
if ( x.GetLength() > y.GetLength())
return 1;
else if (x.GetLength()<y.GetLength()) // If x is inside y
return -1;
else
return 0;
Error (CS0535): ‘Script_Instance.CustomCompare’ does not implement interface member ‘System.Collections.Generic.IComparer<Rhino.Geometry.Curve>.Compare(Rhino.Geometry.Curve, Rhino.Geometry.Curve)’
Could you give me a hint on how a generic interface is implemented? I have read various posts and microsoft articles, but I cannot
Error examples:
Warning (CS0114): ‘Script_Instance.CustomCompare.Compare(Rhino.Geometry.Curve, Rhino.Geometry.Curve)’ hides inherited member ‘System.Collections.Generic.Comparer<Rhino.Geometry.Curve>.Compare(Rhino.Geometry.Curve, Rhino.Geometry.Curve)’. To make the current member override that implementation, add the override keyword. Otherwise add the new keyword. (line 66)
PS: already tried using the override keyword
Error (CS0534): ‘Script_Instance.CustomCompare’ does not implement inherited abstract member ‘System.Collections.Generic.Comparer<Rhino.Geometry.Curve>.Compare(Rhino.Geometry.Curve, Rhino.Geometry.Curve)’ (line 64)
This one pops up often.
I don’t even understand if I am very far off from a correct implementation or if I have some keywords to adjust.
class CustomCurveCompare : IComparer<Rhino.Geometry.Curve>
public int Compare(Curve x, Curve y)
if (x.GetLength() > y.GetLength())
return 1;
if (x.GetLength() < y.GetLength()) // If x is inside y
return -1;
return 0;
// then to sort
List<Rhino.Geometry.Curve> list = new List<Curve>();
// TODO: add items to the list
list.Sort(new CustomCurveCompare());
