I am trying to add a sphere off of the two points I made but on a different layer. the new layer would be named Audio Evaluation. The dataset part of the script can be ignored, later on I will be using that to create the radius of the circle, but for now Just making the circle with a specific layer would be helpful.
thanks,
–Chris
import Rhino
import scriptcontext as sc
import math as ma
filename = 'import.csv'
folder = 'C:\\Users\\gornall72\\Desktop\\'
def raw_data():
rawdata = []
with open(folder+filename,'r') as infile:
for line in infile:
rawdata.append(line)
dataset = []
for data in rawdata:
dataset.append(data.strip('\n').split(','))
header_row = dataset.pop(0)
data_array = []
for i in range(len(dataset)):
data_dict = {}
for j in range(len(dataset[i])):
data_dict[header_row[j]] = dataset[i][j]
data_array.append(data_dict)
print data_array
raw_data()
def Ballast_Points():
search_string = "Ballast"
for layer in sc.doc.Layers:
if search_string.lower() in layer.Name.lower():
for rh_obj in sc.doc.Objects.FindByLayer(layer):
if rs.IsSurface(rh_obj.Id):
rc = rs.SurfaceAreaCentroid(rh_obj.Id)
if rc:
attr = Rhino.DocObjects.ObjectAttributes()
attr.LayerIndex = layer.LayerIndex
sc.doc.Objects.AddPoint(rc[0], attr)
#Brand =
#search_string = Brand
#rs.AddSphere(rc[0],Radius)
sc.doc.Views.Redraw()
response=rs.MessageBox("Evaluate Classroom?",4)
if response!=7:
Ballast_Points()
else:
rs.MessageBox("Evaluation Aborted")
