Hi everybody,
I’m not an expert in programming with python and I would like to know the procedure to overwriting a layer with some lines, after I run again the script. Otherwise, every time I will modify the reference surfaces I will have always new lines.
Thank you
Ale
This is my script for now:
import Rhino.Geometry as rg
surface_base = rs.GetObject('Select the base surface')
surface_top = rs.GetObject('Select the top surface')
points1 = rs.SurfaceEditPoints(surface_base)
points2 = rs.SurfaceEditPoints(surface_top)
for point in points1:
base_points = rs.AddPoints(points1)
for point in points2:
top_points = rs.AddPoints(points2)
for point1 in points1:
for point2 in points2:
lines = rs.AddLine(point1,point2)
rs.ObjectLayer(lines,'dummy')
@alexdell, see oif below does what you want. It just clears the objects on the layer “dummy” before adding the points and lines to it. So whenever you change the surfaces and run the script again, the lines and points are updated.
def DoSomething():
if not surface_base: return
if not surface_top: return
layer_name = "dummy"
# clear the dummy layer, or create it if it is not there
if rs.IsLayer(layer_name):
objs = rs.ObjectsByLayer(layer_name, select=False)
if objs: rs.DeleteObjects(objs)
else:
rs.AddLayer(layer_name)
rs.ObjectLayer(base_points, layer_name)
rs.ObjectLayer(top_points, layer_name)
line = rs.AddLine(point1,point2)
rs.ObjectLayer(line, layer_name)
DoSomething()
note that i changed the code to add the points only once (without duplicates).
c.
