I think i’ve changed the setting for angle tolerance in mesh patch. Any tip for a good value?
- Calculations to synthesize geometries using tolerance angles use the implicit method. Processing nodal components on the same topology will override this method. See the illustrations below for examples of this behavior.The default Tolerance Angle is 45 degrees. This is the recommended setting.
thanks!
The default MeshPatch
angle tolerance is 15.
