I am trying to create a c# component to cycle through different slider values (in a similar manner to galapagos.)
In my example I have tried to change the slider value based on a timer.
It appears to be working - however the grasshopper document crashes most times or temporarily goes into a not responding state before recovering.
You cannot change slider values within solutions. Because this will expire the slider and all objects that depend on the slider causing a potentially infinite recursion of objects expiring other objects. Or rather, it will recurse until the call stack is full at which point you will crash.
If you want to do something 5 seconds from now, thereâs two sensible approaches:
Use a genuine Timer class and handle the callback. Note that these timers run on threads other than the UI thread, and thus the callback will be invoked on a thread other than the UI thread. This means that before you tell Grasshopper to do anything like start a new solution, you must first make sure that your code is hoisted over to the correct thread. This can be done using the Invoke on any winforms control, or RhinoApp.InvokeOnUiThread.
Or better yet, use the GH_Document.ScheduleSolution method which does all the above behind the scenes. You provide a callback when you schedule a solution and inside that callback you change the slider values.
Alternatively you can write your code in a class which runs outside of the solution (like Galapagos). This can mean putting it inside a window and have it triggered by button presses or other UI events, or it can mean creating a class instance which gets âactivatedâ once a solution is finished.
I implement a genuine Timer class for my c# component in visual studio environment.
But the grasshopper completely froze when I trying to reload the script.
Do you have any example for it?
Iâm also developing a c# component with the need to increase a slider value every interval, but it seems like itâs not that simple, and the timer component in grasshopper also isnât doing the job.
Donât use Thread.Sleep(), it just suspends the current thread for a long time and then picks up where it left of. Nothing else is allowed to happen on that thread in the meantime. Itâs a handy method for debugging, but not much else.
I have previously successfully used ScheduleSolution() to handle websocket messages containing a single set of slider values. I used the method you provided here I have also looked at Colibri, but I specifically need to apply sets of slider values at a time. This is to save you time, Iâve done my research.
I am trying to get Grasshopper iterate through a list of âsetsâ of slider values from within my component. I am basically getting grasshopper to batch execute sets of generated slider values that will be read by my plugin when loaded in a grasshopper definition. What is the best way to do this using ScheduleSolution() ? I would like it to start executing the moment the definition loads, and not from a UI event. Can you please provide a code sample for the Class instantiation method you described ?
Thanks
PS- In Rhino6, I am able to change slider values, but the Geometry dependent on these sliders is not recomputing (right now itâs just a cube). The C# script you provided doesnât work either.
To recap - This is the code you provided in 2017 but doesnât work for Rhino6 as is. I use the same logic in my component. This is my modification
and partially works, but behaves unpredictably. The number of times it loops over the sliders is out of control.
Hi! I was trying to create something similar of changing one component with another in C#. Iâm new programming so the idea was a sender component to change the values of a clustered receiver, can anyone help me, plaese?
Sender:
using System;
using Grasshopper.Kernel;
public class SenderComponent : GH_Component
public SenderComponent() : base("Sender", "S", "Send numeric data to receiver", "Test", "Data") { }
protected override void RegisterInputParams(GH_InputParamManager pManager)
pManager.AddNumberParameter("Data", "D", "Numeric data to send", GH_ParamAccess.item);
protected override void RegisterOutputParams(GH_OutputParamManager pManager) { }
protected override void SolveInstance(IGH_DataAccess DA)
double data = 0;
if (!DA.GetData(0, ref data)) return;
// Get the nickname of the target receiver
string targetNickname = "ReceiverNickname";
// Find the remote component with the given nickname within the cluster
GH_Component targetComponent = null;
foreach (IGH_DocumentObject obj in OnPingDocument().Objects)
if (obj is GH_Cluster)
GH_Cluster cluster = obj as GH_Cluster;
foreach (IGH_Component clusterComponent in cluster.ClusterObjects(true))
if (clusterComponent.NickName == targetNickname && clusterComponent is GH_Component)
targetComponent = clusterComponent as GH_Component;
break;
// Check if the target component was found
if (targetComponent != null)
// Send data to the target component
targetComponent.Params.Input[0].AddVolatileData(new GH_Path(0), 0, data);
// Expire solution to update the changes
ExpireSolution(true);
public override Guid ComponentGuid
get { return new Guid("GUID_HERE"); }
Sender:
using System;
public class ReceiverComponent : GH_Component
public ReceiverComponent() : base("Receiver", "R", "Receive numeric data from sender", "Test", "Data") { }
protected override void RegisterInputParams(GH_InputParamManager pManager) { }
pManager.AddNumberParameter("Data", "D", "Received numeric data", GH_ParamAccess.item);
double data = 0;
// Receive data from the sender component
DA.GetData(0, ref data);
// Do something with the received data...
// Output the received data
DA.SetData(0, data);
public override bool Read(GH_IReader reader)
// Perform any additional reading here if needed
return base.Read(reader);
public override bool Write(GH_IWriter writer)
// Perform any additional writing here if needed
return base.Write(writer);
protected override void ExpireDownStreamObjects()
// Expire downstream objects to trigger a re-computation when data is received
OnPingDocument().NewSolution(true);
base.ExpireDownStreamObjects();
