Create thickness from contiguous Surfaces
This is a demo with only three contiguous surfaces (made from a single surface) Its a proxy for 10 carefully made surfaces with high precision that form a single brep. Now it needs thickness such that it becomes a solid for meshing.
The surfaces cannot be joined. A Brep cannot be offset. There is no way to create all the surfaces as one surface from the underlying curves.
A mesh as a final result is ok.
Surface Thickness 001.gh (178.2 KB)
g
Like this?
Surface Thickness 001_re.gh (176.3 KB)
That will work. On the more complex model at higher tolerance the edges dont meet on the offset surfaces beyond about .02, but that is to be expected.
If I took the orignal surfaces and converted them into a mesh, can i join them and offeset them as mesh?
Surface Thickness 001_reV2.gh (212.3 KB)
Heh heh… I can see I have to be less lazy in creating my proxy surfaces
(Using Weaverbird)
http://www.giuliopiacentino.com/weaverbird/
g
This still works though
The power and capability of GH is staggering.
Surface Thickness 003.gh (53.7 KB)
