Hello I have a Sub D surface and I referenced it to the grasshopper. Now I want to make a surface out of this geometry. I got it components from deconstructing brep, but I am unable to create a surface from those points. Can anyone help me on how to do it? I think I am confused on how the component surface from point works.
Do you mind explaining how you created this SubD surface? Did you use Grasshopper or create it manually in Rhino?
Here is a variation on lofting, using the points to create curves in the other direction. The volume of the capped surface (12969) is even larger than before, compared the capped SubD (12820). 101.17%
