Good day,
I would need a script that create a partition of a number range of a list. I found a script that does what I need but the Range is always 5 and I would need it to adjust it to any Value. Also it limited to Integers only List.
There is a PartitionList component, maybe that solves your problem?
this goes through all values val in the list and does the integer division between that value and the divisor of choice: if the result is different from the result of the previous iteration, it slices the list
below average coding skills and not tested extensively tho ![]()
[edit] I think I have completely misunderstood what you are looking for ![]()
maybe: given a list of numbers, divide the Bounds of the values in the list into n ranges and split the original list accordingly
split_Re.gh (14.5 KB)
