I am trying to create a solid of non-planar surfaces that are open via Grashopper.
Here is the Rhino project:
Uploading: Assemblage meuble -.3dm…
Uploading: Assemblage meuble.gh…
Not knowing Grashopper well yet, I have the track of closing it surfaces by integrating via boundary box, or deconstructing the surfaces into curves to connect them together via a loft.
There are other avenues I’m considering but I await your expert feedback!
Many thanks,
Nice thoughts,
Mathéo
Here are the uploaded files :
Assemblage meuble -.3dm (4.7 MB)
Assemblage meuble.gh (1.7 KB)
I have not looked at your Grasshopper definition yet. The input curves of the surfaces I see in Rhino must have been not very precise.
I’d suggest to draw clean curves in Rhino centered on the World origin. This allows the use of polyar arrays and mirroring on the axis system.
Here’s a rebuild:
Assemblage meuble rebuild.3dm (944.7 KB)
Btw: What license is that?
Interface Name: Rhinoceros 6 (6.25.20114.03572, 2020-04-23) - Non défini, version 2020-04-23 - (compiled Apr 23 2020)
For sure, it was not precise and it was not clear why Grasshopper was involved. It was a file with one component !
The aim is to be able to close open polysurfaces
But the shape is interesting.
Here a script that enable to make this type of shape by just drawing a curve on XZ plane with a point on Z axis ans one on X axis. Just choose how much side you want. And it is solid !!!
Symmetric shape.gh (13.2 KB)
Wonderful!
However, I have turned one of the elements of the object as it was originally in the project
Here is the modification:
Assemblage meuble rebuild.3dm (5.0 MB)
Could you tell me how you cleaned up and simplified the lines? Did you vectorise the curves?
Given my old computer I am still under the version (6.25.20114.03572, 2020-04-23).
How would you have proceeded to close these ploysurfaces via Grashopper?
I didn’t give the Grashopper I tried, since I’m experimenting, no result is good, here it is anyway!
test solide.gh (11.2 KB)
I am impressed!
I’m going to dissect what you sent me
Could you send me your bake in Rhino?
Here is the basic idea in a photo of the project:
You have the gh file if the curve is not internalized you just have to make an arc and run the script.
I just rebuilt the curves with one circle. Cut it and then lofted two segments.
Quan_Li
(Quan Li)
April 5, 2023, 3:07pm
14
And a version to make a “cube”.
You just have to draw 2 curves.
Symmetric shapeV2.gh (19.1 KB)
Symmetric shapeV2.gh (17.4 KB)
