Hi, I would like to “cap” this organic tube/surface following this blended curve, more or less. When I do the “patch” command with surface tangency, it pancakes down too much/looks too flat. Any recommendations?
Rhino WIP V9 has a new command called _fillSrf
(WIP - Work in Progress)
test it.
you might split the *blended curve" and use _railrevolve or _networksrf
… or build the “cap” with more advanced techniques - combining 3 or more surfaces…
post you file to get more help !
and also give some background - what are you using the data for.
cheers - tom
