Create a point cloud from points?
I’m going to look very silly in a few minutes, but I tried a lot of stuff that seemed intuitive and searched the NG, to no avail.
How am I supposed to do to create a point cloud from a bunch of points ?
This is what seemed the mosy logical to me :
240301_IMG_How am I supposed to create a point cloud.gh (22.3 KB)
The second part of the question is : can I somehow use the Shrinkwrap component to create a concave hull from a bunch of planar curves ?
This is CAM-related, on this job to avoid impossible toolpaths.
I think I found a way to use shrinkwrap that actualy does the job.
240301_IMG_Interesting use of Shrinkwrap.gh (37.5 KB)
Still, it’s a bit frustrating that I can’t find how to create a point cloud directly in Grasshopper !
Cockroach has a “CloudCreate” component, but the class it creates isn’t compatible with the new “Point cloud” container :frowning:
This could work, the double offset “Un pas en avant Un pas en arrière”
But there is no magic when offset is low, curves are not grouped
240301_IMG_How am I supposed to create a point cloud.gh (23.9 KB)
Quite smart and straightforward, mon cher Laurent !
Yet, I need something more robust, and I think I found the solution (see above).
Do you confirm that there is currently no native GH component that can create a pointcloud ?
McNeel added a bunch of native point-cloud-related components, but the idea that it could be intresting to create a point cloud from within GH didn’t occur to them ???
You will Rant as usual but here is the way
It is the new paradigm in R8, I think it is named PassThrough. It limit the number of components but is less intuitive until we get used to it.
import Rhino
mport scriptcontext as sc
sc.doc = Rhino.RhinoDoc.ActiveDoc
cloud = sc.doc.Objects.Find(PtCloud)
rs.EnableRedraw(False)
cloud_points = rs.PointCloudPoints(cloud)
cloud_colors = rs.PointCloudPointColors(cloud)
print len(cloud_points)
pts = cloud_points
colors = cloud_colors
Im am aware of the pass-through concept.
It is indeed not very intuitive.
Rant closed.
@osuire I agree
RH-81518 point clouds from list of points
Yep, but it didn’t go very far, did it ?
Unfortunately not no, you’ll have to use the method that Andy showed
I’m trying to use Cockroach for it’s implementation of the “Ball Pivot” algorithm to mesh a point cloud like photogrammetry or scanning programs, but it seems to have it’s own point cloud class :
for that you’ll need to contact the authors of that plugin, I don’t know why they needed it to be a different format or if this is a bug.
