Create a new floating viewport and change its display mode
I’m trying to create a python code using RhinoCommon to do multiple Rhino commands at once.
  1. NewFloatingViewport Projection Perspective
  2. MaxViewport
  3. Zoom Extents
  4. SetDisplayMode Mode Shade
I think the following code makes it to step 2, MaxViewport, but I can’t seem to complete the rest quickly. Can someone help? I don’t want to use rhinoscriptsyntax.Command(), because it made my Grasshopper file very unstable executing multiple commands.
import Rhino
import System
from scriptcontext import doc
if r:
    newView = Rhino.RhinoDoc.ActiveDoc.Views.Add("Test", Rhino.Display.DefinedViewportProjection.Perspective, System.Drawing.Rectangle(0, 0, 600, 600), True)
    newView.Maximized = True
I could make it work, sort of… This will change display mode of all views. How can I change the display mode of only the newly created floating viewport? Thank you.
import Rhino
import System
import scriptcontext as sc
if r:
    #Create a new floating view
    newView = Rhino.RhinoDoc.ActiveDoc.Views.Add("TEST", Rhino.Display.DefinedViewportProjection.Perspective, System.Drawing.Rectangle(0, 0, 600, 600), True)
    #Maximize a view
    #Zoom extents
    rs.ZoomExtents
    #Set display mode
    views = rs.ViewNames()
    for view in views:
        rs.ViewDisplayMode(view, "Shaded")
Can someone please let me know why the revised code below doesn’t work? It doesn’t change the display mode… I checked view name to see if Current view is set correctly, and it seems right.
import Rhino
import System
if r:
    #Maximize a view
    #Zoom extents
    rs.ZoomExtents
    #Set display mode
    view = rs.CurrentView("TEST")
    viewName = rs.CurrentView(return_name = True)
    print viewName
Hi @Dongyeop_Lee,
Try this:
import System
import Rhino
projection = Rhino.Display.DefinedViewportProjection.Perspective
rect = System.Drawing.Rectangle(0, 0, 600, 600)
new_view = sc.doc.Views.Add("Test", projection, rect, True)
shaded_id = Rhino.Display.DisplayModeDescription.ShadedId
display_mode = Rhino.Display.DisplayModeDescription.GetDisplayMode(shaded_id)
new_view.ActiveViewport.DisplayMode = display_mode
new_view.Maximized = True
new_view.ActiveViewport.ZoomExtents()
new_view.Redraw()
– Dale
Hi Dale,
Thank you so much for your answer, but I somehow don’t get “Add” method after “sc.doc.Views.”. There is “AddPageView” available, and I get the error message below.
  1. Solution exception:‘GhViewTable’ object has no attribute ‘Add’
    Can you let me know what the issue is?
Hi @Dongyeop_Lee,
Are you running Rhino 6?
Try running the script from Rhino, not Grasshopper.
Here is the help for ViewTable.Add.
– Dale
Yes, I’m using Rhino 6, but I need to run it in Grasshopper. It’s part of much larger Grasshopper file. Is there a way to modify your script to run in Grasshopper?
Maybe. You might ask this question in the Grasshopper category.
– Dale
OK, thank you very much for your help!
I could change Dale’s code slightly to run in Grasshopper, and post it here for anyone looking for a similar solution.
import Rhino
import System
if r:
    #Change display mode to "Shaded"
    newView.ActiveViewport.DisplayMode = display_mode
    #Maximize viewport
    #Zoom extents
    newView.ActiveViewport.ZoomExtents()
    newView.Redraw()
This is exactly what I was looking for. Thanks for sharing!!
made a few changes for my own use but it was really easy to follow your steps.
Is there a way to select one of the existing viewports in Rhino and Maximize it? Not as a floating window, but as a regular viewport (see images):
import Rhino
view = sc.doc.Views.ActiveView
if view:
    if not view.Maximized:
– Dale
Can the new floating window be set top frequently?
fantastically useful. thank you!
Does anyone know why View.Add(“Perspective”, projection, rect, True) doesn’t return a floating window on Mac, but only embedded?
Hi @nickonimus,
It’s been bugged for a while on Mac :pensive_face:
Here’s my work around:
rd is Rhino.Display
rs is Rhinoscriptsyntax
sc is Scriptcontext
            if OS == "Windows":
                # print("Using Windows OS method of viewport creation")
                # This doesn't work on Mac OS
                self.viewport = sc.doc.Views.Add(
                    "MyFloatingViewport",
                    rd.DefinedViewportProjection.Perspective,
                    view_rectangle,
                    floating=True)
            else:
                # print("Using Mac OS method of viewport creation")
                # Test work around for 0 height, 0 width Mac OS viewport bug
                rs.Command("_NewFloatingViewport _Projection Perspective")  # This works on Mac OS
                viewport = sc.doc.Views.ActiveView.ActiveViewport
                viewport.Name = "MyFloatingViewport"
                viewport.ScreenRectangle = view_rectangle
                self.viewport = sc.doc.Views.ActiveView
Yeah seems like only working method through a rhino command.
Thanks!
Please do let me know if you find another working method not relying on running it as a command.
Thank you!
