I am testing my plugin using the latest WIP. Compiled the plugin using VC 2017 and RhinoCommon 6.
The plugin loads by dragging and dropping into Rhino 6 and works as expected.
By invoking Options->Plugins, Rhino Crashes.
Initially I thought that it might be some specific code in my plugin which causes the crash.
I created an empty plugin (Import Plugin type) using the Visual Studio wizard, with all default values. Rhino behaves the same way as described above.
Thank you Dale.
There is one more doubt… Is there any method in RhinoCommon to achieve the help overrides in the C++ SDK AddToPlugInHelpMenu() and OnDisplayPlugInHelp()
Incidentally, I notice that by manually changing the value of the plugin registry AddToHelpMenu to 1, I can enable an entry to Help->Plugin->MyPluginName
