I can’t find options to change those and they don’t use the same color variables as the most of UI elements.
This blue text color control maybe needs to be exposed?
Unusable in gray theme. Is there a file I can manually edit for text colors?
Are Rhino UI items a hard fix? I know it’s the lowest prio, but if it’s just background color value revision, why not have it fixed? @brian
Yes there is this bug
Whenever I want to personalize, all tabs except for cycles … render…Materials do not change
background!!!
@brian
