Are there any plans to match color values with R6? Maybe expand on UI colors controls?
We are ready to switch the whole department to R7 and this would be very, very desirable for us.
Also, I just setup makeshift UI, exported R7 BETA options and now when I’m trying to import the colors back its says:
It doesn’t like its own, natively created options file…
Found the culprit - for some reason Rhino writes blank here:
As soon as I enter some symbol there, options.ini becomes importable.
@brian Is there any other threads that discuss this topic? I searched but i cant find any that discuss the UI coding changes. It appears to me, at least for what i have set up and begun to poke around, that the OPTIONS > Appearance > Colors > General > “Window Color 2” color pick is being used for more surface area in the 7/Beta build than was utilized in R6. Can you confirm?
@Asterisk have you modified your Windows operating system colors? The “Edit Text” dialog does not match the colors that I see when I set my Rhino to a darker set of custom colors.
Our goal for V7 is to have the UI to that can be docked to the main Rhino window be more consistent with respect to the UiPaintColor settings in Rhino’s settings system. Floating dialogs will not be addressed until the future. This is why we are specifically not advertising any support for a “dark mode” in V7. We are getting closer, but still have a long way to go.
All of the colors are controlled by the UiPaintColor settings that can be found in the advanced settings page in Rhino’s options.
Is there a doc that describes what all of these control? I can’t find UI elements for about third of them. Don’t see a UI change anywhere when I change them.
@stevebaer, by looking at the code, those custom controls (that JohnM made) wrap Eto controls and use different Eto.Drawing.SystemColors (maps to System.Windows.SystemColors on windows) for most states (Enabled, Disabled) and hard coded colors for other states (Red for invalid text)
The tab mouse over highlight is a nice touch in R7, but the active tab should keep the highlight color, so it’s clear at a glance what tab is active. R6 had it, now R7 only has a border outline that’s pronounced not nearly enough. Did people not like the active tab persistent highlight?
So I just imported back Appearance from Options.ini exported earlier to fix the colors I broke and it imported default colors essentially making me re-setup the UI colors.
Is UI colors export broken in R7? Why is it exporting UserName blank?
I’m not sure why it is exporting a UserName at all. I’ll make a bug for a developer to look at this. Are you using ExportOptions to make this ini file?
I might know the issue - I was exporting options.ini to Google Drive folder and windows has issues writing stuff from other programs there or some such.
