@nathanletwory, on the topic of Nuget and copying local, is there a way to force the Nuget packages to copy local?
I don’t know if that is possible.
The question that needs to be asked: why do you need it to be copied in place? You get an invalid plug-in setup if you do…
I need it to work for a Unit Test I’m writing that needs to reference the package
RhinoCommon was never designed to work without Rhino and will fail many unit tests if you are trying to use RhinoCommon as an independent dll.
I would recommend using rhino inside for unit testing or Rhin3dm if you need to run tests on a computer where rhino is not installed.
We have a rhino inside unit testing example in our developer examples github repo.
Hey @stevebaer,
I had a look at this Repo and it’s super helpful, I’ve had a play with it and it runs Rhino/GH very well. I tried adding a link to my plugin, however I now have the opposite problem and it is copying RhinoCommon etc local. If I delete them just before the program loads it looks to the correct location and runs nicely. I will continue testing.
