Found a solution. It copies everything from the source dir with a Boolean trigger.
using System.IO;
private void RunScript(string sourceDir, string destDir, bool copyTrigger, ref object A)
if(copyTrigger)
foreach (string dirPath in Directory.GetDirectories(sourceDir, "*", SearchOption.AllDirectories))
Directory.CreateDirectory(dirPath.Replace(sourceDir, destDir));
foreach (string newPath in Directory.GetFiles(sourceDir, "*.*", SearchOption.AllDirectories))
File.Copy(newPath, newPath.Replace(sourceDir, destDir), true);
