Convert rhinoiside code to python!
Hello, i tried to convert this c# code to python without success, any help very appreciated
  private void RunScript(ref object Receive_pt)
    Receive(Component);
    Receive_pt = pt;
  // <Custom additional code>
  Point3d pt;
  bool registered = false;
  IGH_Component comp = null;
  void Receive(IGH_Component component)
    if(!registered)
      Rhino.Runtime.HostUtils.RegisterNamedCallback("ToRiR_pt", RiRhino);
      comp = component;
      registered = true;
  void RiRhino(object sender, Rhino.Runtime.NamedParametersEventArgs args)
    Point3d values;
    if (args.TryGetPoint("point", out values))
      pt = values;
    comp.ExpireSolution(true);
Python try
def Receive():
    registered = False
    component = gh.Kernel.IGH_Component
    if registered:
      rh.Runtime.HostUtils.RegisterNamedCallback("ToRiR_pt", RiRhino);
      comp = component
      registered = True
def RiRhino():
    args = rh.Runtime.NamedParametersEventArgs()
    if args.TryGetPoint("point"):
       pt = args[1]
    comp.ExpireSolution(True)
    return point
Receive_str = RiRhino()
I can see two things without testing : you are setting registered to False inside the function, not outside as in C#, and the C# test is if not registered : you have reversed it in Python
Thank you @Dancergraham
When i set registered outside the function, i got an error:
Runtime error (UnboundLocalException): Local variable 'registered' referenced before assignment.
Something wrong with ghenv and component and more and i can’t configure the problem.
send_receive.gh (8.7 KB)
You can pass the value of registered in to the function as a second argument to clear that error…
Thank you Graham i will try
