Hello everyone, I need help to convert THIS python Script to c# in Grasshopper(this script shows all the plugins and cluster and component used in the algorithm in the panel) i try it but get this error for panel…
@Mahdiyar
ot_get Component__.gh (18.3 KB)
C#=
// Grasshopper Script Instance
#region Usings
using System;
using System.Collections;
using System.Collections.Generic;
using System.Drawing;
using Rhino;
using Rhino.Geometry;
using Grasshopper;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
using Grasshopper.Kernel.Special;
#endregion
public class Script_Instance : GH_ScriptInstance
#region Notes
Members:
RhinoDoc RhinoDocument
GH_Document GrasshopperDocument
IGH_Component Component
int Iteration
Methods (Virtual & overridable):
Print(string text)
Print(string format, params object[] args)
Reflect(object obj)
Reflect(object obj, string method_name)
#endregion
private void CheckCanvas()
bool note = false;
var ghdoc = Instances.ActiveCanvas.Document;
foreach (var obj in ghdoc.Objects)
if (obj is GH_Panel panel && panel.NickName == "All Components Used")
panel.UserText = AnalyzeActiveGhDoc();
panel.ExpireSolution(true);
note = true;
break;
if (!note)
MakeCompsPanel();
private void CheckCanvas2()
bool note2 = false;
if (obj is GH_Panel panel && panel.NickName == "PlugIns Used")
panel.UserText = formatted;
note2 = true;
break;
if (!note2)
MakePlugInsPanel();
private void MakeCompsPanel()
var panel = new GH_Panel();
panel.Name = "All Components Used";
panel.FillColor = Color.LightSkyBlue;
panel.Font = new Font("Trebuchet MS", 10);
panel.Multiline = false;
panel.Attributes.Pivot = new PointF(-345, 0);
panel.Attributes.Bounds = new RectangleF(-330, 0, 330, 450);
Instances.ActiveCanvas.Document.AddObject(panel, false);
private void MakePlugInsPanel()
panel.Name = "PlugIns Used";
panel.Attributes.Pivot = new PointF(-690, 0);
panel.Attributes.Bounds = new RectangleF(-330, 0, 330, 150);
private Tuple<Dictionary<Guid, GH_AssemblyInfo>, Dictionary<Guid, GH_AssemblyInfo>> Libraries()
var coreLibraries = new Dictionary<Guid, GH_AssemblyInfo>();
var addonLibraries = new Dictionary<Guid, GH_AssemblyInfo>();
var server = Instances.ComponentServer;
foreach (var obj in Instances.ActiveCanvas.Document.Objects)
var objId = obj.ComponentGuid;
if (obj is IGH_Component)
if (objId != Guid.Empty && !coreLibraries.ContainsKey(objId) && !addonLibraries.ContainsKey(objId))
var lib = server.FindAssemblyByObject(obj);
if (lib != null)
if (lib.IsCoreLibrary)
coreLibraries.Add(lib.Id, lib);
else
addonLibraries.Add(lib.Id, lib);
return Tuple.Create(coreLibraries, addonLibraries);
private string AnalyzeActiveGhDoc()
int compCount = 0;
var dictComponents = new Dictionary<string, Dictionary<string, Dictionary<string, int>>>();
var component = obj as IGH_Component;
var category = component.Category;
var subCategory = component.SubCategory;
var name = component.Name;
if (!dictComponents.ContainsKey(category))
dictComponents[category] = new Dictionary<string, Dictionary<string, int>>();
if (!dictComponents[category].ContainsKey(subCategory))
dictComponents[category][subCategory] = new Dictionary<string, int>();
if (!dictComponents[category][subCategory].ContainsKey(name))
dictComponents[category][subCategory][name] = 0;
dictComponents[category][subCategory][name]++;
compCount++;
string username = Environment.UserName;
string panelText = $"{DateTime.Now.ToString("DATE- yyyy.MM.dd TIME- HH:mmh")}\n";
panelText += $"Last saved by - {username}\n";
panelText += $"Total Components - {compCount}\n";
foreach (var category in dictComponents)
foreach (var subCategory in category.Value)
foreach (var comp in subCategory.Value)
panelText += $"{category.Key}.{subCategory.Key}.{comp.Key} - {comp.Value}\n";
return panelText;
private void RunScript(bool x, ref object a)
if (x)
var coreLibraries = Libraries().Item1;
var addonLibraries = Libraries().Item2;
List<string> adds = new List<string>();
foreach (var lib in addonLibraries.Values)
if (!string.IsNullOrEmpty(lib.Name))
adds.Add($"{lib.Name} {lib.Version}");
formatted = string.Join("\n", adds);
CheckCanvas();
CheckCanvas2();
Python=
ghenv.Component.Name = "OTools_GetComponents2"
ghenv.Component.NickName = 'O_GetComps2'
ghenv.Component.Category = "OTools"
ghenv.Component.SubCategory = "3 | Debugging"
try: ghenv.Component.AdditionalHelpFromDocStrings = "1"
except: pass
import Grasshopper as gh
import System.Drawing as sd
import time
from collections import defaultdict
import sys
import os
comp = ghenv.Component
ghdoc = comp.OnPingDocument()
def get_time():
# Function to format time
_t = time.localtime()
_format = "DATE- %Y.%m.%d TIME- %H:%Mh\n"
return time.strftime(_format, _t)
def format_dict_info(dictionary, info, level = 0):
for key, value in dictionary.iteritems():
_indent = '.'*3*level
if isinstance(value, dict):
text_fmt = "%s%s:" %(_indent,key)
info.append(text_fmt)
#recursive call here
format_dict_info(value, info, level + 1)
else:
text_fmt = "%s%s - %s" %(_indent,key,value)
def analyze_active_ghdoc():
try:
compcount = 0
#getgrasshopper document
ghdoc = ghenv.Component.OnPingDocument()
# create nested dictionary to store component info
dict_components = defaultdict(lambda: defaultdict(lambda:defaultdict(int)))
for obj in ghdoc.Objects:
if type(obj) is not gh.Kernel.Special.GH_Group: #Fixed this to filter out groups in count
dict_components[obj.Category][obj.SubCategory][obj.Name] += 1
compcount = compcount+1
# Format output text
username = os.environ['USERNAME']
panel_text = "%s"%(get_time())
panel_text += "Last saved by - %s\n" %username
#panel_text += "Total Components - %s\n" %(ghdoc.ObjectCount)
panel_text += "Total Components - %s\n" %compcount
mytext =[]
format_dict_info(dict_components, mytext)
for t in mytext:
panel_text += "%s\n"%t
return panel_text
except:
print "Unexpected error:", sys.exc_info()[0]
def CheckCanvas():
note = False
for obj in ghenv.Component.OnPingDocument().Objects: # check the components in the definition
if type(obj) is gh.Kernel.Special.GH_Panel: # check to see if its a panel
if obj.NickName == "All Components Used": # check the panel name
print "Found "+obj.NickName+" Panel"
obj.UserText = analyze_active_ghdoc()
obj.ExpireSolution(True) # http://www.grasshopper3d.com/forum/topics/triggering-solution-refresh
note = True
if note == False:
print "I didn't find it, I'm just going to make it for you. Soon as you let go of the button, I'll go ahead and add some info....so let go already."
MakeCompsPanel()
def CheckCanvas2():
note2 = False
if obj.NickName == "PlugIns Used": # check the panel name
obj.UserText = formatted
note2 = True
if note2 == False:
print "I didn't find it, I'm just going to make it for you"
MakePlugInsPanel()
def MakeCompsPanel():
#create the panel
Panel = gh.Kernel.Special.GH_Panel()
#set the panel attributes
Panel.NickName ="All Components Used"
Panel.UserText = analyze_active_ghdoc()
Panel.Properties.Colour = sd.Color.LightSkyBlue
Panel.Properties.Font = sd.Font("Trebuchet MS", 10)
Panel.Properties.Multiline = False
#add the panel
ghdoc.AddObject(Panel,False,ghdoc.ObjectCount+1)
#set the location and size of the panel
Panel.Attributes.Pivot = sd.PointF(-345,0)
Panel.Attributes.Bounds = sd.RectangleF(-330,0,330,450)
def MakePlugInsPanel():
#create the panel
Panel.NickName ="PlugIns Used"
Panel.UserText = formatted
#add the panel
Panel.Attributes.Pivot = sd.PointF(-690,0)
Panel.Attributes.Bounds = sd.RectangleF(-330,0,330,150)
def libraries():
coreLibraries = {}
addonLibraries = {}
objids = {}
server = gh.Instances.ComponentServer
if objids.has_key(objId): continue
objids[objId] = ""
if lib == None: continue
if coreLibraries.has_key(lib.Id) or addonLibraries.has_key(lib.Id): continue
if lib.IsCoreLibrary:
coreLibraries[lib.Id] = lib
else:
addonLibraries[lib.Id] = lib
return coreLibraries, addonLibraries
if x == True:
coreLibraries, addonLibraries = libraries()
adds = []
for id, lib in addonLibraries.iteritems():
if lib.Name != "":
adds.append("{0} {1}".format(lib.Name, lib.Version))
formatted = '\n'.join(map(str, adds)) # serialize input _Text list to a formatted string
print formatted
CheckCanvas()
CheckCanvas2()
