as you can see, they use colored “dots” or “squares” to visualise pointclouds with rgb values…
I wonder if this or something similar could be done in Rhino to… would it be possible to replace every point in a pointcloud with e.g. a simple cube ? After the conversion we could join the cube to a single mesh ,to make the scene workable again and then apply the orthophoto to the mesh…
I wonder If anyone could help me with this, I could really use it!
Yes, I know that one, but thanks anyways! … the idea was to be able to use the data in a real time environment (actually it is a large landscape model …) to simulate vegetation, so I indeed need real geometry … any ideas?
P.S: I attached 2 pictures to show the problem… I have a meshed ground layer of the landscape and i would like to ad the vegetation in a way that it is not super massive …
I got this for now, quicky because it’s late.
Select a pointcloud and a seed object and it will copy the seed from 0,0,0 to the points and give it the color of the pointcloud points…
import scriptcontext as sc
import Rhino
def populate_pointcloud():
cloud_id = rs.GetObject('Select Pointcloud')
seed_id = rs.GetObject('Select Seedmesh')
pcloud = rs.coercegeometry(cloud_id)
seed = rs.coercegeometry(seed_id)
for item in pcloud:
color = item.Color
location = item.Location
item_seed = seed.Duplicate()
item_seed.Translate(Rhino.Geometry.Vector3d(location))
item_id = sc.doc.Objects.Add(item_seed)
rs.ObjectColor(item_id, color)
Hey Willem, thank you so much! i will try it ASAP! in the meantime I tried the approach for the not so mentally gifted (…like me ) and tried the trusty old CopyObjectToPoints python script by Mitch … in principle this seems to work !
Hi Willem please excuse my ignorance, I tried to copy your script, pasted it in the script editor and tried to run it… that did not work … what am I suposed to do with this again?
