The only thing to watch is that the curve seam is on a straight segment so that segment is not simplified fully - use the CrvSeam command to move the seam to a corner before converting.
I have few questions about the parameters for the ‘Convert’ command
“Angle Tolerance” :
how to understand the value “20”? - I thought it was in radians.
“MinLength” :
I intended to use “MinLength” to make sure there are no short segments because contour is to be used for cutting, where short segments are not recommended… - how can make use of it?
