Conversion from string to float
’ <’ not supported between ‘str’ and ‘float’ . And there is no option to change the input data type to float. And cannot change the data type in python also
Hi Jenin, can you provide additional details?
What data types are d and U?
I cant change it to float
@Jenin It looks like you are using the GH_CPython plugin, which is no longer maintained, and is obsolete in Rhino 8 since CPython is directly provided there without additional plugins.
Can you try moving your code to a “Script” component in Grasshopper in Rhino 8 (or the _ScriptEditor in Rhino if you are not using Grasshopper)?
