WT4
October 20, 2026, 7:33am
1
Can someone point out where I can find the above component. It allows you to connect a plethora of sources to a receiving component without having to drag the component all over the canvas. Many thanks
flokart
October 20, 2026, 10:02am
2
@WT4 maybe you search for telepathy plugin. Telepathy S is modified version of the original , which is also mention .
[image]
Telepathy is not supported for a long time already, so i made a version for myself with some extended features - like
convert multiple existing wires into telepathy components
delete all telepathy components and replace them with normal wires before sharing the document with someone who does not have the plug in.
delete telepathy components that share same key and replace with normal wires
search keys
optimized performace through cashing (2048 recievers on one screen - 37 fps o…
WT4
October 21, 2026, 12:51pm
3
Thank you. Will try this out.
