Connect exterior faces from host faces in RTR grasshopper
I need the surface of a building imported from revit as a enclosed box, but with the openings intact. I filter out the exterior walls, but since the walls comes from Revit they have a thickness and the brep is not closed. I tried with cap brep but it does not work.
My question: Can i either split the brep into 4 pices or join the eges?
Hi Magnus,
Do you have access to pollination? They have developed methods to do this type of workflow fairly effortlessly.
