Hi guys, I have trouble following the Deployment to Production Servers Guide
As far as I can tell everything should be set up correctly
aws server has the rhino-compute service running
the …/version api gives me the current version of rhino and compute
core hour billing is active
However when I use the sample appserver to send requests, the only response is
{"message":"Internal Server Error","stack":"Error: Internal Server Error\n at getParams (D:\\Code\\ComputeApp\\compute.rhino3d.appserver-main-opener\\src\\definitions.js:47:11)\n at processTicksAndRejections (internal/process/task_queues.js:97:5)\n at async D:\\Code\\ComputeApp\\compute.rhino3d.appserver-main-opener\\src\\routes\\template.js:46:14"}
everything works when i use a local compute server, but I’m not even sure where to start troubleshooting here
is there some compute logfile I can look at to figure this out?
Edit:
Is this maybe a duplicate of this:
So no local appserver + remote compute?
If yes: Why exactly is that? I thought the gh definitions are sent within the first request.
