Dear Rhino developers,
I am trying to find a way to compress viewport in 1 dimension, or “zoom in” 1 dimenion instead of two in parallel view.
Is it possible?
With my limited knowledge and experience in programming I have assumed viewscale maybe the option I am looking for
ViewportInfo.ViewScale Property
However it requires SizeF as input which as far as I understand stores two values, but in ViewScale description x, y and z are mentioned. If this property could help me achieve my goal, could someone give more light, how to set it up? I will be thankfull for any answer.
Łukasz
Ok code below sets viewscale:
ViewportInfo viewportInfo = new ViewportInfo(doc.Views.ActiveView.ActiveViewport);
viewportInfo.ChangeToParallelProjection(true);
viewportInfo.ViewScale = new System.Drawing.SizeF((float)0.5, 1);
RhinoView view = doc.Views.ActiveView;
view.ActiveViewport.SetViewProjection(viewportInfo, true);
RhinoApp.WriteLine("Viewscale dimensions are " + viewportInfo.ViewScale.Width.ToString() + " width and " + viewportInfo.ViewScale.Height.ToString() + " height.");
doc.Views.Redraw();
I see its changing viewscale values of current viewport, its changing viewport to parallel, but I do not see any scaling of view, so it apparently is not doing what I expected.
Is there any hope?
Ok I have found that, not ViewScale, but FrustumAspect is what allows to compress view in 1 dimension. Someone in future may find this information useful.
https://developer.rhino3d.com/api/RhinoCommon/html/P_Rhino_DocObjects_ViewportInfo_FrustumAspect.htm
