I’m new using rhino, I’m starting to work around with threejs/rhino3dm/rhinoCompute
I want to create a base64encoded Mesh from an .obj file using the js librairie of rhino3dm
I’m loading my file with the threejs OBJLoader and then I found that DracoCompression.compress(mesh, options) is taking a Mesh as parameter (documentation is in TODO state
But it seem’s a Threejs Mesh is not a Rhino Mesh ??
// The error :
Object { name: "BindingError", message: "Cannot pass \"[object Object]\" as a Mesh const*", stack: "BindingError: Cannot pass \"[object Object]\" as a Mesh const*\nextendError/errorClass<@https://files.mcneel.com/rhino3dm/js/latest/rhino3dm.js:8:91019\nBindingError@https://files.mcneel.com/rhino3dm/js/latest/rhino3dm.js line 8 >
How can I do to convert my Threejs Mesh into RhinoMesh ?
(I try to implement directly the dracoEncoder but it’s a bit complicated for my level of understanding of virtual 3D objects)
Thank you for your help
