After offsetting them, they are to be used to create a surface and must be in the SAME structure as the input (other operations follow that must also return the curves to the same list structure after their operations)
… and slowly the mysteries of the ages were revealed to the neophyte…
While this works, the list is not consistent.
Which magical module do I use to create the same structure
because later down the pipeline, this is going to box me into another corner…
Thank you so much for your time, but I am creating lists using a proxy for the model I am working with (the example file). Please ignore the geometry and just consider the lists
The set of logic that creates a list with stations of the same number is vastly more complex than the example I have posted.
There are multiple operations that occur to the curves as a function of their location and other geometry.
I have had to stop working on geometry to try to get my head around lists because I keep getting boxed into impossible corners with lists.
For this project, the only way I can see to manage the curves that in each set, that processed by multiple different functions is to keep the input and output list format consistent, ie grouped by station (numerically sequential)
Each operation results in some different list format and I must rearrange the list to again match the input - in this instant case, renumber the stations to eliminate two stations with the same number
I took another look, and - apart from what @HS_Kim already pointed out -, you can simplify your definition a lot. In fact, you can get rid of all the tree operations, like this:
I am REALLY reluctant to post this because its just another proxy for the model I am working on that is much more complex so PLEASE DO NOT MAKE THIS EXAMPLE WORK. This thread is a list problem NOT a geometry problem.
It is just to help you visualize how there can be many curves at each section.
In the example I posted, to find the area at station 16 I would have to know what item in the list station 16 is for each curve:
The list needs to be structured so that at ITEM 16 (station 16) ALL the surfaces at that section pop out of the tree for further processing by more functions
so really the problem is back to transforming this list
into a sequential list that matches the input
The start of the problem is the composited list (not just one set of lines)
The essence of the problem is that most operations (REPLACE, DISPATCH, SUBCURVE, LOFT, YOUNAMEIT) either require a flat list, or produce a flat list that must then be transformed to match the input ie, each curve/surfacebrep at the corresponding station (item number)
Its beginning to look like I need to just construct the list from scratch after every operation using the x value of the curve end points. Is there an APPEND module that appends items onto a list (complete with all the branches) ?
OK, so do I understand this correctly? Your curve is divided into an x-amount of “stations”, and each station had one or two surfaces that belong to it? In this scenario, I don’t exactly understand to which station the surfaces belong that seem to lie between two?
This example creates a list of planar curves jumbled in their location within the list to represent some operation f(x) upon the curve (with unpredictable order in the resulting list)
The second section of code, uses their X value to arrange and group them at their respective x locations in order within the list such that item 12 corresponds to the 12th X location, in this case 12 units along the X axis.
Comments welcome:
Each component automatically picks an input parameter as the guiding one for creating output data. Usually it’s the input with the most complex tree structure, but the logic is more complicated than that. By manually assigning a principal parameter you override that choice and force all output data to adhere to that particular structure.
