Is there a way to pass a number by right click of the grasshopper component in AppendAdditionalComponentMenuItems ?
I have only seen boolean parameters, but numbers would be really helpful.
Could someone show an example of such implementation?
namespace MenuInput
public class MenuInputComponent : GH_Component
private double _number;
public MenuInputComponent() : base("MenuInput", "Nickname",
"Description", "Category", "Subcategory")
protected override void RegisterInputParams(GH_InputParamManager pManager) { }
protected override void RegisterOutputParams(GH_OutputParamManager pManager)
pManager.AddNumberParameter("O", "O", "O", GH_ParamAccess.item);
protected override void SolveInstance(IGH_DataAccess DA)
DA.SetData(0, _number);
public override void AppendAdditionalMenuItems(ToolStripDropDown menu)
var setInt = Menu_AppendItem(menu, "Set Number");
Menu_AppendTextItem(setInt.DropDown, _number.ToString(CultureInfo.InvariantCulture), null, TextChanged, true);
private void TextChanged(GH_MenuTextBox sender, string newText)
_number = Convert.ToDouble(newText);
ExpireSolution(true);
protected override System.Drawing.Bitmap Icon => null;
public override Guid ComponentGuid => new Guid("d2bc99d5-36b1-4139-b42d-f21ac50d3a90");
MenuInput.zip (22.5 KB) MenuInput.gha (6 KB)
That is super useful, thank you so much, works like a charm.
Is there a way to access those two click buttons?
I’d like to NOT recompute every time the text changes
I only want the text change to take effect when one clicks the commit changes
ps. I’m aware that I could use Windows.Forms classes and script the above behavior myself. Just curious.
namespace MenuInput
private string _text;
public MenuInputComponent() : base("MenuInput", "Nickname", "Description", "Category", "Subcategory") { }
Menu_AppendTextItem(setInt.DropDown, _mber.ToString(CultureInfo.InvariantCulture), null, TextChanged, true);
setInt.DropDownItems[1].Click += CommitChanges;
_text = newText;
private void CommitChanges(object sender, EventArgs e)
if (RhinoMath.EpsilonEquals(Convert.ToDouble(_text), _number, double.Epsilon)) return;
_number = Convert.ToDouble(_text);
MenuInput.zip (23.2 KB) MenuInput.gha (6.5 KB)
very nice!
sneaky Menu_AppendTextItem actually adds two more menu items…
