Dear users
I have created several curves to fit my structures profile. And I’m getting the output as invalid lines even with a higher tolerance. I tried several times remodelling it and I couldn’t find where I’m making the mistake.
Could someone share your previous issues similar to this. And provide suggestions?Ba_Shell_Grid.gh (74.6 KB)
Your data going into both the Length goals and the Angle goals has one zero and several very near zero length lines. I think it would work best if you can generate the geometry so that between each node there are just one or two line segments, of fairly similar length.
