I created a simple brick wall code with YouTube video.
I tried to put in the mapping and domains elements code but couldn’t, that’s the result right now.
I also tried to create a brick wall where the bricks are layed in different angles, from small angle to bigger, with gradient, like accordion, like this.
Thanks a lot!! This is so helpful. Amazing.
I have another question - how can I create the same pattern, but the gradient parameter that changes is the space between the bricks instead of the angle? like this:
I adapted my file so the distance between the bricks changes. The attractor points (the green spheres in the render) indicate the areas for compaction of the wave: harmonic brick wall V2.gh (32.8 KB)
