Hello! Hope you’re well. I made a parametric brick wall, but I need help extruding bricks out of the wall. I’m not sure how I’d do that. I want the extrusion to have a set pattern, perhaps every other brick? I’m attaching the script!
Yess, that works perfectly! Thank you so much. However, for the assignment that I’m doing I need to use the Nurbs curve command when I create a primary parametric wall. Do you know how I can include that as part of the script? I added the command, but it curves quite a bit and isn’t seamless. I would really appreciate the help. Thank you!
I’m sorry I don’t understand how it all connects. Could you please send an image of how you attach it all together? Really appreciate the help. Thank you!
@Quan_Li Can you please explain how it works for you since it gives me errors towards the end when I apply the extrusion part of the script? Thank you!
