Hey, I have a problem on command line. I do not know why but command is not activated unless I write the command completely. For example Exs means Extrudesurface but now I am typing completely after that I got the command activated. Do you have any ideas about it?
So you have an alias ‘Exs’ which is set up to run the command _ExtrudeSrf? and it’s no longer working? Can you check under Options>Aliases to see if the alias is still there?
Also, if it’s the autocomplete that has stopped working, check in Options>Advanced (type autocomplete in the search box) and see if it got deactivated…
