The command history panel stays static even when new command are typed… for example: run the Length
command, the panel stays static and one has to manually scroll to the newly added line.
wim
(Wim Dekeyser)
September 5, 2023, 8:28pm
2
Hi Rudi -
That’s a known issue for users on macOS Ventura 13.x.
→ RH-73417 CommandHistory doesn’t scroll to the bottom
Tom_P
September 5, 2023, 8:35pm
3
… yes the same in V7 here.
I created a new topic to keep V7 / V8 category separated.
I am also waiting for a fix !
recorded videos are worthless, setting in the classroom is quite demanding.
should be a V7 fix in my opinion.
brian
(Brian Gillespie)
September 29, 2023, 12:23am
4
RH-73417 is fixed in the latest BETA
atair
September 30, 2023, 10:57am
7
sorry, its not fixed properly:
Its better, but still easy to break:
for(int i = 0; i < 100; i++) {
RhinoApp.WriteLine("Test: " + i.ToString());
After running this a few times it scrolls only halfway or more, but never to the end. And does not recover. Dragging a box etc. results in erratic jumping around. Once the Buffer is is full (around 4k lines) it stablizies a bit, but still:
What i see:
[image]
what it is:
[image]
Edit:
I don’t think my script has anything specifically to do with it, so i assume …
