[Mac]Command history panel jumps
I haven’t used rhino in a while and and I’ve noticed a little bug which used to be no problem on mac. I have two panels on my right sidebar, one is the command history and below that is the layer panel. Recently whenever I do something the command history jumps and doesn’t show the last command. I think it is not recognising the second panel and setting itself so the last command would show at the bottom of the sidebar. The order of the panels doesn’t matter if I switch them around, the problem persists.
I hope these screenshots explain the issue better:
I have also tested this in rhino 8 wip and have the same issue
I have the same problem since updating to Ventura. The “Panels: Command History” doesn’t show the latest command or action at the bottom line, but something in the center of the command history, so you have allways to scroll down to the latest information. I could not find any preference to fix this.
so far we haven’t managed to reproduce that here. Pls provide _Systeminfo
Rhino 7 SR26 2023-1-9 (Rhino 7, 7.26.23009.07002, Git hash:master @ 92abcf7c453c78a236526390d91d0ac1f6779143)
License type: Educational, build 2023-01-09
License details: Cloud Zoo
Apple macOS Version 13.2.1 (Build 22D68) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro14,3
Language: en-GB (MacOS default)
AMD Radeon Pro 560 OpenGL Engine (OpenGL ver:4.1 ATI-4.9.51)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: Radeon Pro 560
Displays: Color LCD (258dpi 2x)
Graphics processors
Intel HD Graphics 630 (1536 MB)
Radeon Pro 560 (4 GB)
Color LCD (1680 x 1050)
USB devices
Apple Inc.: Apple T1 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.26.23009.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.26.23009.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.26.23009.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.26.23009.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.26.23009.7002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.26.23009.7002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.26.23009.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.26.23009.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.26.23009.7002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.26.23009.7002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.26.23009.7002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.26.23009.7002
Apple M1 Max, 32 GB, macOs 13.2.1
Rhino Version 7 (7.27.23032.13002, 2023-02-01)
Rhino 7 SR27 2023-2-1 (Rhino 7, 7.27.23032.13002, Git hash:master @ 4a0030c0d354560df03764f4f49ecc5d119e5118)
License type: Commercial, build 2023-02-01
Apple macOS Version 13.2.1 (Build 22D68) (Physical RAM: 32Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,4
Language: en
Apple M1 Max (OpenGL ver:4.1 Metal - 83)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Apple
Render version: 4.1
Z-Buffer depth: n/a
Total Video Memory: 21845 MB
Graphics: Apple M1 Max
Displays: Unknown (92dpi 1x), Unknown (92dpi 1x)
Graphics processors
Apple M1 Max
DELL P2419HC (1920 x 1080 @ 60.00Hz)
DELL P2419H (1920 x 1080 @ 60.00Hz)
USB devices
Logitech: USB Receiver
3Dconnexion: 3Dconnexion Universal Receiver
Bluetooth devices
None
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/Users/RGK/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/RhinoFileVersion/RhinoFileVersion.rhp “Rhino 3DM File Version” 7.0.7639.20582
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.27.23032.1002
thanks for providing SystemInfo @rgkoehnsen and @thesimontrapp
I’ve added https://mcneel.myjetbrains.com/youtrack/issue/RH-73417/CommandHistory-doesnt-scroll-to-the-bottom
Can’t find the issue on youtrack. I’ve tried reinstalling but the issue persists. I’ve also tried resetting the theme and settings to no avail.
It’s there, but not fixed yet, you get nothing when you click the link? It is open to public view.
The link didn’t work for me yesterday but now it works.
Anyone managed to fix this? I’ve recently updated to Ventura too and I have this issue.
nope - i have that on two machines, V7 and WIP V8… we just have to wait till someone recognises this as a critical bug and something starts moving… Also having this as a V8 goal is somehow strange, as it severely affects the user experience in V7.
It applies to all scrollable windows with text - also the bottom left hidden command history panel
Ditto some of the comments above…just coming to the Mac version and the History Window not displaying the last command at the bottom like it does for me in R5 makes the window such a pain after even the shortest time modelling. Hope this gets fixed.
cheers,
Sochin
I am experiencing the same bug on rhino 7 and 8 for a while now. Please fix it.
Hi -
RH-73417 is currently on the 8.0 list, so this is expected to be fixed within the next few months.
I see that the Mac version is still not taken 100% seriously
RH-73417 is fixed in Rhino 8 Service Release 15 Release Candidate
sorry to pop this topic up again -
Version 8 (8.2.23346.13002, 2023-12-12)
Mac os x ventura 13.5.1 (22G90)
intel macbook pro
the commandline sometimes scrolls to nervous / to much or is grayed out.
tried to get a sequence that allows a reproduce-able workflow but I did not manage.
using line, rectangle boundingbox in front view
repeat the commands with space and combine everything in a random order…
this is what i get
( 2 fails, one as I expect)
Can you please subscribe to the 8.3 RC and see if it’s better? We’ve revamped the command history window in 8.3
still have this grayed out command history in Rh 8.6 Version 8 (8.6.24101.05002, 2024-04-10)
hi @Tom_P I was just testing this and could manage to get this at some point:
But that is only when I perform an erratic repetition of commands hitting the spacebar. It resets again when I start acting normal. So what I want to know is: Once you get the grayed out panel, does it reset the next command you run or does it stay put like that?
Also, what happens to that panel state when you run _CommandHistory at that point?
