Command for set Cplane to Surface?
I’ve been using an alias for setting Cplane to object, which is !_CplaneObject — but the same doesn’t seem to work for setting Cplane to Srf. I thought it would be something like !_CplaneSrf
Does anyone know how I can find the command script for this? Thank you!
the standard _cplane command has a surface option.
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/cplane.htm
try _cplane and use the surface option
not tested but i think your old Alias was linked to
_cplane _surface
for fine-tuning of the command / macro see:
https://wiki.mcneel.com/rhino/basicmacros
and
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#information/rhinoscripting.htm?Highlight=macro
Thanks - I’ve figured it out! – the following alias works: !_Cplane _S
dear @martin88smith
the solution should be
'_Cplane _Surface
_s will just act as s - as a short version for surface.
but those one-character-shortcuts are not guarantied to be consistent over updates.
! will stop other commands
’ will allow this command to be nestable - especially for cplane related stuff, this is important
the above macro is also used in the official cplane toolbar.
more about macros here
kind regards -tom
