we try to connect our software with an open Rhino 6.4 and it doesn’t succeed.
If we connect to Rhino 6.1 it works.
We use the com-interface with VS C++.
With older versions (Rhino 4 /Rhino 5) we haven’t any problems.
Hello Dale,
our code works with every installed Rhino (Rhino4, Rhino5, Rhino 6.1).
But it doesn’t work with latest Rhino 6.4.
What could be the reason?
I attached the source to a sample project to my prior reply. Even if you cannot use th proejct settings, you can use the source code.
If your appplication works on one system and not another, then repair the Rhino installation on the system that isn’t working. From Control Panel, pick Programs and Features > Rhino 6 > Change. When the Rhino installer dialog appears, click “Repair”.
we used our source code since Rhino 4. It worked for years. No problems with Rhino 5.
Only with Rhino 6 we have the problem that it will run only on the developer computer.
I don’t think that the source code is the problem. But what is the problem? Maybe the project settings? x64, Unicode, MFC static or shared. I don’t know.
I’m the collaegue of Michael. There are still problems in this topic. From the link you posted https://mcneel.myjetbrains.com/youtrack/issue/RH-47742
we can’t see that the bug is fixed so far. Also the manual registration doesn’t work satisfiying in all cases.
Furthermore after the installation of Rhino7 one of our customer can’t use the interface to Rhino6 anymore.
Would be great to have a solution soon.
Thank you very much for your quick response. We do it like you described since Rhino4! The first problems occurs since Rhino6 (see conversation so far). Maybe you could contact your colleage BrianG for further details. As far I understand from the protocol: https://mcneel.myjetbrains.com/youtrack/issue/RH-47742
the bug fix is shifted from one release to another. But of course I might interpretate it wrong.
