Hi @pruemm,
I’ve spend a little time reviewing this (old) thread and the YouTrack item.
First, the E_NOINTERFACE
result code is not usually a registration problem. Plus, you can use OLEVIEW
and see the type library registrations.
Rhino is an out-of-proc COM server. This is most likely the cause.
Rather than just importing the type library using #import
, try using the the Class Wizard MFC Class From TypeLib. This is what I used to build the TestRhinoCom
sample that I posted above.
Hope this helps.
– Dale
