Colour Gradient on 3D Surface/Mesh base on point name
Hi all,
This is my first posting here, had been here for quite some time to search for solutions every now and then.
Have a question, what is the best way to colour gradient on 3D surface/mesh according to point name?
I have tried few things and closest that I can get to my goal is by using Grasshopper.
Since I am not a developer, script writer and just play around Grasshopper for few days, so my knowledge in Grasshopper is very limited.
If i can separate the processes into steps, it will be like this :
A) Select 3D surface/mesh from Rhino
B) Select points (points will be individually named) from Rhino
C) Colour gradient will be plotted on the 3D surface/mesh based on points name
Anybody can help in giving me pointers/hint/solutions to this?
I have attached a sample file of the geometry and points with name which I am using to learn this.
Many thanks,
Nik
p/s : I have a bit of background on C++, VB and Python but all is self taught and Im still learning
Sample_Excercise.3dm (47.1 KB)
Hello - I guess I’d start by getting a mesh of the box to a pretty fine mesh and assign vertex colors to the mesh according to some interpolation, linear most likely, of distance from neighboring points.
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_BrepFace_GetMesh.htm
https://developer.rhino3d.com/api/RhinoCommon/html/P_Rhino_Geometry_Mesh_VertexColors.htm
Hi Pascal,
Thanks for this, will look into it.
