Color gradient for multiple points on Mesh [Solved]
Yes, I’d like to make a heat map of a band of points hovering over a mesh, but it seems that my gh definition only tests for one point and all the other points are disregarded.
Updated gh:
Colorize Mesh 01 Forum.gh (29.1 KB)
Is there an easy way to achive what I want?
// Rolf
missing
Argh, I saw that the color was different (green, it should have been pink) and suspected a thirdparty component, and so searched three times for the “std” component. What is its name when I can’t find it?
Edit:
I found Bounds & Remap instead:
// Rolf
No PC at the moment, but you will have to graft the mesh vertices on the distance component and then use a sort component on the output of distance and then list item to take the smallest ( item 0) and flatten and use these values.
Colorize_Mesh_2018Feb14a.gh (31.6 KB)
Yes, thanks, problem solved.
// Rolf
